A16 GTX - a long story
Re: A16 GTX - 'real' enough for me
Been a bit concerned re oil consumption on this one - had feared piston rings or at least valve stem oil seals.....................anyway, had a cylinder compression test and a very thorough checkover of all the breather pipes and connections with Tim at the Phirm today.
Compression all fine - number 1 cylinder slightly lower than 2,3 and 4 but all well within tolerances.
Another fun drive home - the long way.
Only added about 700 miles since Edition, another bloody oil leak, this thing seems to eat rocker cover gaskets.........
Oil pressure issue? That's the usual suspect for blowing the top gasket.GTXTRA wrote:Only added about 700 miles since Edition, another bloody oil leak, this thing seems to eat rocker cover gaskets.........
mr.brown wrote:Oil pressure issue? That's the usual suspect for blowing the top gasket.GTXTRA wrote:Only added about 700 miles since Edition, another bloody oil leak, this thing seems to eat rocker cover gaskets.........
hi mate, as mentioned earlier, it had a check on that down at the phirm back in the spring - all in order.
thebrief_1979
had the same problem myself - very small leak but def from rocker cover gasket - I am using the cork ones at the moment for authenticity reasons and have sold all my rubber ones - think i am going to have to give in and go for a mk3 golf rubber gasket and replace the studs and bolts also.
I put it down to not using it though - i recon the cork dries out - only a theory though
1993 MK2 Flash Red GT2 - sold
Mk1 gls - nearly
Mk1 gls - nearly
- Reverend Frog
I changed mine for a cork one in my first year of ownership and it was grand after that
Re: A16 GTX - a long story
replaced a stretched seat cable on this one this morning, hope to get an MOT sorted at months end.
Head gasket, as i've been suspecting for a while, needs changing, it's gone at the rear offside - apparently a regular KR weakpoint.
Off to Dr Saunders @ the Phirm in time for Inters.
112k miles on what is now a 27 year old engine - can't complain too much to be honest and having had a new oil pump/bearings done last year I'll know all is well for a while longer once sorted.Bill wrote:
In for head gasket and cambelt today and, on inspection, the head in dire need of some decoking and general rebuild/tlc.
Explains why this hasn't always felt as special as the 16v people suggest it should compared to the DX cars.
Back on the road in time for Inters fingers crossed.
