This is what it's all about.treefingers wrote:reminded me that i'm doing this for enjoyment!
Got a spare rear top brace if you want to use it as a pattern. Proper one that sit in between the towers and bolts into the chassis.
Cheers man. Just had a look at the Qpeng site. Looks like a good kit, and looks like it saves a lot of hassle! A bit steep for me though, if I was going standalone I had budgeted for about half what they want for a kit.Mr Funk wrote:Looking good buddy,
Engine management wise I was looking at the qpeng kit. Proper plug and play and eliminates the arsing about.
Suspension wise 6/700 will get top of the line. A fair few of us use Weitec adjustable coileys and they're gorgeous. Less than your estimations as well.
some interesting reading there.. thanks for that. from what I gather the guy is basically saying make sure you balance your brakes for the balance of the weight of the car. i guess to do it properly I'd need to finish the car, weigh each end and adjust the brakes accordingly? I can't see that I can make the brakes any worse however, they were awful before! With bigger master cylinder, servo and front discs I hope I will be ok.. maybe 256 won't be big enough but I'll see. with some good discs and tyres it should help.dozzum wrote:Might wanna do some research on brakes and getting it all balanced right, weight transfer and bias etc.
Some basic explanations here http://www.mgf.ultimatemg.com/group2/br ... Brakes.htm
Im definatly no expert but all the changes you are making to the car are going to drastically change the braking performance.
Probably best putting an adjustable bias valve in allowing you to use trial and error to get it right.
Its sounding like its gonna be awesome.
Keep the updates coming.
sounds good.. what size wheels are you running?Mr Funk wrote:Forgot to mention, you're pretty spilt for choice on brakes as well.
I went mental and fitted a complete Willwood 288mm kit, never looked back. Mainly because the brakes are so good I'm completely unable.
Where are you based fella? If you're close you're more than welcome to have a ride......
Giggidy.
Tim - we're southerners. It's all motorways down 'ere
