1982 1.5 CL Auto
- The Milkman
- The Milkman
Re: 1982 1.5 CL Auto
Doesn't look too bad consdering it was cold, wet and painted on my driveway. If I get a chance before the weather gets too bad I'll try and get some filler and topcoat on the outside and then in the spring get the other side welded up.
Primer can absorb moisture. If you are going to leave the arch in primer for a while try this paint http://www.rust.co.uk/000-custom-epoxy- ... r/p501025/#
- The Milkman
Cheers mate, aerosols are about as technicl as I get with painting, I might give it a quick blast in body colour until it gets done properly.Little_bro wrote:Primer can absorb moisture. If you are going to leave the arch in primer for a while try this paint http://www.rust.co.uk/000-custom-epoxy- ... r/p501025/#
- The Milkman
Covered the inside wheel well with waxoyl today, looks like shit but hopefully it'll keep the tinworm at bay.
While I was in the boot I noticed a small puddle, traced it back to the rear light and found another bodge.
Some sort of sticky, gunky crap that obviously doesn't work as it's still leaking and I bet it's gonna be a bastard to get off!
Nice work - your welding and fabrication looks great. Looks like you've done quite a bit before.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
- The Milkman
I wish!! Welding and fab work is all done by a friend of mine, I'm sure he'll be chuffed with the compimentsMikeH wrote:Nice work - your welding and fabrication looks great. Looks like you've done quite a bit before.
I stick to basic mechanical stuff and a bit of electrics.
This is the stuff that the dealers sell to cure leaks, it is easy to get off and effective when applied correctly.The Milkman wrote:Covered the inside wheel well with waxoyl today, looks like shit but hopefully it'll keep the tinworm at bay.
The Milkman wrote:Cheers mate, aerosols are about as technicl as I get with painting, I might give it a quick blast in body colour until it gets done properly.Little_bro wrote:Primer can absorb moisture. If you are going to leave the arch in primer for a while try this paint http://www.rust.co.uk/000-custom-epoxy- ... r/p501025/#
Get your top coat on quick. Use a hair dryer to warm up the area then apply sevral coats within 10 - 15 minute intervals between coats.
The rust co epoxy paints can be applied with a brush then sanded down. In fact I've just put some on the rust spots on my pewter mk2 scirocco untill I can get time to do a full repaint.
- The Milkman
Ah, ok. Is that the best cure? Can I not just get new seals?ianaudia4 wrote:This is the stuff that the dealers sell to cure leaks, it is easy to get off and effective when applied correctly.The Milkman wrote:Covered the inside wheel well with waxoyl today, looks like shit but hopefully it'll keep the tinworm at bay.
- The Milkman
Little_bro wrote:Get your top coat on quick. Use a hair dryer to warm up the area then apply sevral coats within 10 - 15 minute intervals between coats.The Milkman wrote:Cheers mate, aerosols are about as technicl as I get with painting, I might give it a quick blast in body colour until it gets done properly.Little_bro wrote:Primer can absorb moisture. If you are going to leave the arch in primer for a while try this paint http://www.rust.co.uk/000-custom-epoxy- ... r/p501025/#
Was going to have a play today but it hasn't stopped bloody raining! :(
Probably not! I bought the last one from VW UK back in 2010 for my Scala!The Milkman wrote:Ah, ok. Is that the best cure? Can I not just get new seals?ianaudia4 wrote:This is the stuff that the dealers sell to cure leaks, it is easy to get off and effective when applied correctly.The Milkman wrote:Covered the inside wheel well with waxoyl today, looks like shit but hopefully it'll keep the tinworm at bay.
This is looking really good and inspiring me to crack on with mine, just need some time off work and the weather to play ball!
1990 MK2 Scirocco GT 1.8
1982 MK1 Golf 1.6 GLi Cabrio - unfinished project - up for sale soon!
1983 MK1 Golf 1.8 GTI Cabrio - waiting on shell swap due to tinworm
The Milkman wrote:I wish!! Welding and fab work is all done by a friend of mine, I'm sure he'll be chuffed with the compimentsMikeH wrote:Nice work - your welding and fabrication looks great. Looks like you've done quite a bit before.
I've seen a lot worse done by 'professionals'. You should buy him a few beers if you're not already paying him.
- The Milkman
Bugger :(ianaudia4 wrote:Probably not! I bought the last one from VW UK back in 2010 for my Scala!The Milkman wrote:Ah, ok. Is that the best cure? Can I not just get new seals?ianaudia4 wrote:This is the stuff that the dealers sell to cure leaks, it is easy to get off and effective when applied correctly.The Milkman wrote:Covered the inside wheel well with waxoyl today, looks like shit but hopefully it'll keep the tinworm at bay.
