Page 12 of 38
Re: 1982 1.5 CL Auto
Posted: Thu Aug 07, 2014 1:58 pm
by The Milkman
Package arrived from VW Heritage, new headlight adjusters/mounts
Posted: Thu Aug 07, 2014 1:59 pm
by The Milkman
Metal plates arrived as well, so I mounted the front one. Just need some black caps for the screws
Posted: Thu Aug 07, 2014 2:16 pm
by The Milkman
I also want to blank off the aerial hole in the wing, I never use the radio and think it will look tidier. The hole is about 15mm and the only aerial blanks I could find, that were polished or chromed, were 30mm!! I managed to find rubber grommets at the right size but didn't really want a basic grommet in there.
Found these, they are apparently 18mm across so should be a good fit, I've ordered a set to see.
Posted: Sun Aug 10, 2014 3:58 pm
by The Milkman
Posted: Sun Aug 10, 2014 3:59 pm
by The Milkman
Posted: Thu Aug 28, 2014 12:32 pm
by The Milkman
I was going to leave the inner crap guards off the front so that you could see my newly painted and detailed inner wings, but I don't want to be worrying about stone chips and the like so they're going back on (until she get's lowered and then it depends if they get in the way).
So quick trip down to local fastner place for some stainless fixings, £2 later...
I still need to clean and polish the guards but I can do that while she's away being welded up.
Posted: Thu Aug 28, 2014 12:36 pm
by The Milkman
I dug all four wheels out from hiding, they're not perfect but neither is the car so they should look ok. I'm going to keep the 195/50x15's on the rear but change the fronts for 165/50x15, it looked over-tyred when I tried the 195's on the front.
Posted: Thu Aug 28, 2014 12:37 pm
by The Milkman
Started taking the rear end apart ready for her to go off for welding
Posted: Thu Aug 28, 2014 12:39 pm
by The Milkman
Inside where the bumper irons go looks nice and solid so the tinworm doesn't seem to have crept too high.
Posted: Thu Aug 28, 2014 12:40 pm
by The Milkman
Posted: Thu Aug 28, 2014 12:42 pm
by The Milkman
The boot carpet was a little bit damp and I found a small puddle in the back
But apart from that it all looks very clean
Posted: Thu Aug 28, 2014 12:44 pm
by The Milkman
Posted: Thu Aug 28, 2014 12:45 pm
by The Milkman
by The Milkman
Posted: Thu Aug 28, 2014 12:47 pm
by The Milkman
