crusty rusty rocket
Re: crusty rusty rocket
i finally managed to get a belt that im hoping will fit (6PK 1033) from a peugeot.
this should allow me to keep the alternator up high and not have to bring it lower to fit the shorter "correct" belt.
success the pug belt fits the abf setup a treat so i can keep the alternator in its origenal position.
got all the other service items too and set about fitting the rotor arm and dizzy cap.
weirdly the rotor was glued on? so resorted to breaking it up with molegrips to get it off and fitted the new one.
the old dizzy cap was a right state with most of the electorde burnt away and severley pitted.
also bled the brakes yesterday which showed up a couple of leaks.
2 were the master cylinder pipe ferrules which i forgot to tighten up somehow, and the other was the front right brake flexi which needed knipping up to stop a leak.
also fitted the handbrake cables which went straight on no issues, (so to clarify for anyone else wanting to do the mk3 rear disk brake conversion the standard scirocco 16v handbrake cables fit straight on).
so hopefully once the fuel pump is bolted on and wired in the car can be put back on its wheels for engine fitting.
one quick question, is it easier to fit a 16v engine (with gearbox attached) through the top of the engine bay? or is it better to fit it from underneath?
bengould
Post by bengould »
I've had my 20v in and out several times. I have always gone through the top with an engine crane. Never tried from the bottom, but there isn't much in the way whichever way you go.
Ben.
cheers ben
thats a weight off my mind as ive been a bit worried about doing it either way.
lifting the car high enough to go over the engine does not sound a safe idea and doing it from above sounds likely to scratch the new paint.
i suppose patience is the key and preparation.
is it worth taking the bonnet off to give more clearance?
Ant and I removed a standard 1.8 engine from a mk2 from below - it doesn't need to go all that high if you've got something fairly flat to put the engine on.
bengould
Post by bengould »
You don't need to take the bonnet off. Just don't use too long a chain/rope with the hoist. If you can keep the engine as close to the arm as possible you limit the height you have to get the arm before the engine is clear of the car.
There is plenty of room in the bay to get the engine in and stay clear of the paintwork. The only awkward bit is getting the gearbox past the brake servo. But if you drop it in at an angle it makes it much easier.
Ben.
88GTX
Post by 88GTX »
Same here, albeit with a standard DX engine. I took mine out and dropped it back in from the the top. Bonnet was left on, just propped up higher with a piece of wood.
ant
Post by ant »
When I put the 1.8t in mine I took the bonnet off to make it a little easier which I was glad of at the time, i tilted the engine with gearbox down and still ended up bashing all my new paint work, even with 3 people putting it in. Wish I had put engine in 1st then attached gearbox from underneath.
1988 Mk2 Scirocco Scala 1.8t AGU - now sold :-(
Tim_R
Post by Tim_R »
I generally lift the car up, slide the engine under and lower the front down again, then lift the engine up into place.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
I removed my bonnet and put my engine in from above then side the gearbox in from below, attached the drivers side engine mount, angled the engine down and attached the gearbox to the engine but I had my drive shafts in place so had to line up/fix them to the gearbox as well. There is plenty of room to stand over the engine and slide the gearbox on with out the other stuff attached to the engine.
This was on a DX engine and I did it this way as I was on my own and I damaged the paint getting the engine and gearbox out in one go from above during removal.
cool, cheers for the info peeps.
i think i will separate the gearbox from the engine then and put them in separately.
does sounds like a much easier way of doing it.
really looking forward to it now!!!!
You can see there is plenty of room with the radiator removed and you can just about stand in the engine bay to pick up the gearbox and slide it on to the engine. I have a 4 to 1 exhaust manifold so I placed that in before fitting the engine as there was plenty of room.
This is my Golf but I can't imagine much difference in a Scirocco
It's a little tricky getting the drive shafts in the right place as I found I had to get them loosely into the gearbox flanges as I could not fit them afterwards but I did leave my shafts fitted when the engine was out.
bengould
Post by bengould »
To get around the driveshaft issue you can just unbolt the front wishbone bolt and pull the wishbone out of the front mount. This gives you plenty of room to get the CV joint into the gearbox cup.
Ben.
bengould wrote:To get around the driveshaft issue you can just unbolt the front wishbone bolt and pull the wishbone out of the front mount. This gives you plenty of room to get the CV joint into the gearbox cup.
Ben.
ah thats a nifty trick, the engine should be in by thursday so will be taking the gearbox back off and preping the motor with rags to protect the engine bay.
gotta find the engine mount bolts as they seem to have gone walkies :?
