Re: The Weight Saving thread!
Posted: Sat Apr 30, 2011 2:13 pm
Ok...weight saving...off the top of my head:Rocco Horror wrote:
Hmm! That's an idea!
Seriously though, it'll be easier to take a little bit of weight from lots of places rather than lots of weight from a few places. I was amazed at how heavy the bonnet is for example, so with a little creative angle grinder work to the inner skin, I'm sure there are a few pounds to come out of that.
Any more suggestions? Doors?
If you start cutting out the support structures from the bonnet it'll flap in the wind as drive down the road, and deform easily. Proper weight saving is expensive, fibreglass/carbon/kevlar panels (bonnet, front wings, door skin and tail gate) will all save major weight, but will cost a bomb if you can even find them. For the doors, you'll probably want to keep the frames and bond the light weight skin onto it, so they don't flap in the breeze. Doors should probably only be done if you have a full roll cage in for rigidity and safety.
Ditch all the standard seats and replace the fronts with bucket seats - fixed back ones for major savings.
Gut the interior, replace the dash with just an instrument pod
Get rid of all the extra electrics in the car, and strip the wiring out
Ditch the heater matrix and blower fan, you'll even carry less coolant around then - but you do require a method for clearing the windscreen for MOT.
Take all the underseal off from under the car and replace it with Por15. Spend a while with a hot air gun melting all the wax out of the crevaces
Polycarbonate (or similar) windows - that rear screen must weigh a tonne
loose the bumpers - they're not a legal requirement...but I think you'll have to loose the tow eyes as well
Reduce unsprung weight by going for alloy brake calipers (4 pots probably), coil overs and light weight alloys
Move the battery to behind the passenger seat to even out the weight distribution a little
Carefull selection of exhaust materials
Rust - Natures weight saving.
Once you've done all that, and you still want lighter, things start getting silly:
Half size fuel tank
Cut the spare wheel well out and replace with a fibre/carbon panel
Take a hole cutter to anything not structural
Cut the roof skin off and replace with an aluminium panel (not recommended)
After all that, the resulting car could be down to about 750 - 800kg, but it won't be the most comfortable ride, and you'll have spent a fortune. Would be fun though.
