Re: Oil Filter Change
Posted: Thu Oct 28, 2010 10:04 am
GT Matt wrote:Firstly, drain the oil into a suitable receptical. Take the sump bung and replace the copper washer with a new one. Once the oil has drained, wipe around the drain hole, refit the the sump bung and tighten but do not overdo it.bensspares wrote:firm hand tight is good enough just check it doesnt leak at the gasket whilst the engine is running.
Now the filter. A pair of adjustable/water pump pliers will also easily remove the filter.
Once removed, clean the filter housing with rag so it is nice and shiny and make sure the old oil filter seal is still in the filter and NOT stuck to the housing.
Next, take your new filter, open your new oil, dip your finger into it and smear a thin film of fresh oil around the rubber seal on the top of the new filter.
Now fit the filter onto the engine and, once it goes tight, give it a good twist to tighten using both hands and this should suffice.
Now fill the ening with the fresh oil. Initially fill to the max mark then start the engine. Watch the oil pressure light and make sure it goes out. Once it does go out, leave then engine running for about 10 secs then turn off.
Now allow the oil to settle for about 30 secs (making sure the car is on level ground) and dip the oil level. ALWAYS WIPE THE DIPSTICK AND DIP, NEVER TAKE THE READING AS IT JUST COMES OUT OF THE DIPSTICK TUBE.
Top up unitl level is at MAX. Now run the engine and check for leaks - fingers crossed, all is well
A MAZING !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thanks so much
