Cleverness!! I'm using a Beru dizzy cap and rotor, the cap and stems are about 10mm shorter than that of a standard 16v cap. I've also spaced one side of the servo out a tad to give that little extra. Works a treat.richieA wrote:how have you got the dizzycap in? im confused! i got mine on but the king lead was no-were near EVER EVER fitting...!
As for the tubes, they're angled on the manifold plate by a few degrees, it's a loverly snug fit, I ran it without the circlips to see what would happen and the vaccum didn't suck them off so they're on well!
Just been for a blast, turns out peak power is around 5500rpm atm, at least thats when you REEEALLY feel it push you back in the seat, anywhere above 2500rpm is scarily quick though.
