Re: AGG to replace a DX
Posted: Thu Jun 18, 2009 9:56 pm
Hi guys a little update and some more questions...
1) This AGG is from a passat and the oil filter housing points down, i'm guessing this is the same as a golf and so will be ok?
2) Which water pump did you use? The AGG one or the DX one or is there no difference?
3) What belts did you use (cambelt, alternator), AGG, DX or something else?
4) Which alternator did you use, AGG or DX?
5) for the headgasket did you use a 1.8 or 2.0 gasket?
I've got the AGG pretty much stripped down now and I ordered the conversion kit from TSR to save time, I'm taken pictures and documenting as I go so I can put up a guide for anyone else wanting to do this....
Any help as usual greatly appreciated
