OEM Coil Springs
RussGLAuto
Re: OEM Coil Springs
Post by RussGLAuto »
Evening gents,
So after some refurbishment of the original top spring mounts got both units assembled and refitted. I spoke to soon when I said the near side rear was a doddle to remove, the offside rear fought me! Some muppet had assembled the shock top bolt incorrectly and locked the load spreading washer with a second nut under effectively jamming it in place and hidden by the top bushing... Oh, and the top nut was x-threaded! Ended up having to clamp a mole grip to the shock shaft while I wrestled it off. :dash:
There may have been some beeps needed during the afternoon...
The only part I reused was the top spring mount and spacer, after de-rusting they got a coat of Jenolite rust converter. Great stuff and works really fast in 15 mins. Then a couple of coats of grey primer before the black topcoats. In fact, I'm considering giving the rear beam a coating of this stuff as it turns any surface rust black.
As an aside you don't need to use the spring compressors when removing or mounting (I guess you all knew that but this is my first effort!) however they are needed to compress the new spring on fitting to the shock so that the top mount can be fitted correctly in place.
RussGLAuto
Someone previously got their nuts in a twist:
Again, took the time to degrease and scrub the wheel arch while waiting for the paint to dry on the top mount. That stainless steel powder coated filler neck from Dreadnaught Customs still looking pristine after two years service. Thanks Tom!
Ready to fit:
Right, now for the front units and wishbones... :pilot:
Coming together nicely.
You will definitely need the spring compressor for the fronts.
If you are reusing your front struts and fitting new inserts I’ve found when you Jack up the front try and loosen the big nut holding the shock insert inside the strut as you can get more leverage when the struts attached to the car. I use a big pair of stillsons or a pair of water pump pliers may also do it depend on how rusty they are.
Bit more info here and he has but a red circle around the nut I’m talking about.
https://vwgolfmk1.org.uk/forum/index.ph ... lace-front
GT_II
Post by GT_II »
I'm glad it's going well - looking forward to hearing your progress on the front struts. I have the same spring set to fit to my GT II at some point - need to get rid of those pesky MOT advisories.
RussGLAuto
Thanks for the comments chaps.
I pushed the boat out and got the Bilstein front struts and inserts, but thanks for the tip. I will be keeping them for a refurbish at some point.
Slightly more nervous about the front replacement, mainly regarding the eccentric bolt and positioning so as not to upset the tracking. I have seen the thread from the Mk1 Golf site, good advice but was hoping for a more accurate way. May have to take it for a check at my local Bush tyre centre post fitting.
Also going to replace the wishbones, got some heritage power flex bushings for that. All ready to go! I'll post some more pics next week.
Russ
WreckTangle
Post by WreckTangle »
The eccentric bolt is used to adjust the camber. It may be best to get a cheap camber gauge off eBay and use this to set the camber. -0.5 to -1deg. Then get the tracking done.
GT_II
Post by GT_II »
Most garages and tyre places now do a full 4-wheel alignment check/adjustment including camber and toe - though not much use doing the rears as there is nothing to adjust. Official VW alignment table for front axle (covers Mk1 and Mk2 Scirocco):
The basic figures for injection and carb models are the same, but the permitted tolerance for camber on the injection cars is smaller. So both camber and toe are ideally slightly positive. Footnote 1 states that for very sporty drivers, toe can be set to -10' and camber set to +40'.
Can anyone tell me what positive figures for toe and camber in this table actually mean? Front of the wheels slightly further apart than the back and top of the wheels slightly further apart than the bottom, maybe?
RussGLAuto
WreckTangle wrote: Sat Nov 13, 2021 11:13 pm The eccentric bolt is used to adjust the camber. It may be best to get a cheap camber gauge off eBay and use this to set the camber. -0.5 to -1deg. Then get the tracking done.
Hi WT,
I was thinking something along these lines after watching Edd China's episode on his outspan orange refurbishment! Minute 27:00 on the link seems a very simple and reasonably accurate way of measuring the camber:
https://www.youtube.com/watch?v=MtJIkKH_dnI
However, something even better is this I found on Amazon:
Think I'll bite the bullet and give it a go, anything better than guessing... I can then measure the angle prior to removal and replicate on re-fitting. Looks like it's a magnetic fit to the brake disk.
RussGLAuto
GT_II wrote: Sun Nov 14, 2021 1:21 am Most garages and tyre places now do a full 4-wheel alignment check/adjustment including camber and toe - though not much use doing the rears as there is nothing to adjust. Official VW alignment table for front axle (covers Mk1 and Mk2 Scirocco):
Thanks GT_II,
Where on earth do you find your info? Have you got one of those elusive VW Garage manuals? Been looking for copies on E-Bay for a while, all I can find is German copies! :good:
GT_II
Post by GT_II »
On erWin, you can access digital versions of all workshop manuals, both English & German. There are more manuals available in German than in English, so it pays to download both. The benefit of the digital versions is they also include supplements issued after publication of the original manual.
Registering is free, so you can see what is available before you pay. Browse carefully before you pay, as you can download as many manuals as want once you've paid for your 1 hour "trolley dash", which from memory costs just 9 Euros. I think I downloaded every single English manual for the Caddy and Fox as well as both English and German manuals for the Scirocco in that time, plus a selection of VW "Self Study Guides".
As you are replacing a lot of stuff on the front I would get the car set up properly with a garage that has all the equipment, it’s not cheap but neither is replacing front tyres that wear out uneven.
Both camber and tracking will need doing but after fitting and wait a couple of weeks for things to settle down before getting it set up.
I’ve got the gauge in your link above and it does work well but the main problem is to get the reading, the car need to be on a level surface and on its wheels, I use a 14” spirit level (you can use any flat straight bit of metal) across the wheel edges and then but the gauge onto the spirit level and get the reading. (You need a vertical surface to get the gauge to zero before starting)
You can Jack the car up remove the wheel and fit the gauge onto the brake disc then set the gauge to zero, do the work and then move the camber back to zero once it’s all back together. Once it’s all done and the car has settled check the camber with the car on the ground and on its wheels again. When ever you adjust the camber it will move the tracking so it’s camber 1st then tracking.
I run mine with 0.5 negative camber and it seem to wear the tyres out fairly evenly.
If you are replacing the wishbone it’s a good time to fit a lower strut brace as they make a massive difference to the handling…
I fitted one like this last year.
https://www.ebay.co.uk/itm/191991884333 ... BMhIqv4aNf
RussGLAuto
GT_II wrote: Sun Nov 14, 2021 10:48 am On erWin, you can access digital versions of all workshop manuals, both English & German. There are more manuals available in German than in English, so it pays to download both. The benefit of the digital versions is they also include supplements issued after publication of the original manual.
Never heard of it but looks like a good website thank you. I can feel some downloading coming on!! :ebay:
RussGLAuto
mark1gls wrote: Sun Nov 14, 2021 10:53 am As you are replacing a lot of stuff on the front I would get the car set up properly with a garage that has all the equipment, it’s not cheap but neither is replacing front tyres that wear out uneven.
Yep, agree 100%. I just wanted to get Gladys in the 'ballpark' before taking it to Bush tyres Spalding who have got all the laser alignment gizmo's. They have a Mk1 Golf GTi owner mechanic working for them who sorted out my wayward tracking and off centre steering wheel. She kept pulling to the left with me having to constantly steer to the right to keep it on the road! Not ideal...
He took the steering wheel off, centred the passenger front then adjusted the tracking arm on the drivers side until centred then put the steering wheel back on.
She's been hands off straight and true and the steering wheel level ever since!
I did give them the Haynes manual camber and toe info to make sure it was correct. They didn't have a Mk2 Scirocco on the laser alignment gizmo! :hugegrin:
Russ
