Thank you everyone for your replies.. ive been busy so havent had chance to get anything done on the rocco..
Starting from whiteshark,
gasket on full pump is okay no leaks,
i replaced all fuel pipes apart from the ones under the car, although i did push air through them and seemed fine(blocked one end and checked for leaks)
HT leads and ignition coil was changed yesterday(still have the issue)
There is some dirt in the filter but nothing major i would say.
Mark1gls,
Next i will be restricting return line
The rubber flange and gaskets are new,
And the air box is bottled down..
Kidcrewbob,
The vacuum hoses on the carburetor are new :)
Sent from my SM-G950F using Tapatalk
Engine dying whilst driving
- Mk2liamjones
