Bluetooth Stereo Suggestions/Experience
Fresco3000
Re: Bluetooth Stereo Suggestions/Experience
Thanks for all the feedback guys, will post a few pics of connectors and reply properly shortly.
1980 Mk1 Scirocco GLi / 1986 T25 Caravelle / 1989 Mk2 Scirocco GT
Fresco3000
P,
That sounds like a good solution, how did it connect in between? Did you need convertors?
Also interested in how you mounted the various parts.
Cheers!
Cheers!
Fresco3000
Wire questions, coming out of the cars original stereo wiring are four cables that connect to the black power block.
The cables are coloured, red, brown, yellow/white & blue/white.
Can anyone advise what these are in relation to live, earth etc?
I'm assuming the brown block is all speaker cables.
Red = live 12v (possible switched live)
Brown = earth for power
Yellow/white = permanent 12v live
Blue/white = power/switch for electric aerial.
The other block is for the speakers.
Fresco3000
Thanks Mark1gls
So now it's just a case of identifying the pins on the radio and matching them up!
Fresco3000
So... I got it to power up, but it displayed ‘phone SAFE’.
I was expecting the SAFE and I have the code but it wouldn’t let me enter anything.
After a bit of digging I found some refs to the ‘phone’ mode being down to an additional pin being connected. Have yet to check again.
To add to the joy, the battery completely drained so I’ve obviously got something wrong.
Question. As I will never need the stereo on unless i’m driving, is the permenant live still essential?
In other notes, this week the following has happened. Choke broke of from behind dash, had to remove vent and squeeze finger behind it to close it.
Brake lights now stick on, have to tap pedal a few times to switch them off.
Lower ignition cowling fell off, had been taped on by previous owner.
Rear wiper has gone, hoping it’s just the relay.
blakey
The stereo will need the permanent live for the memory, so you don't have to enter the code every time and storing radio stations and general settings.
Brake lights could have flattened the battery, check the switch, may need replacing, unless there's an issue with it contacting the pedal.
The rear wiper issue 'could' be related to the cowling, mine sometimes doesn't make proper contact at the switch. With the upper cowl off you can see the contacts of the switch close to the stalk itself.
'89 Sapphire Scala Inj.
Member No. 1455
Member No. 1455
Fresco3000
Cheers Blakey,
The brake lights were’nt on, I tap it every time I park up to make sure they aren’t left on. Does need the switch replaced.
Interesting about the cowling, would never have imagined that would be related.
Fresco3000
Bizarre development.
I have been advised that I need to join up the blue and yellow cables to run this stereo. I tried that and while it didn’t spring into life an unintented error did result in activity, when I connected pin 2 to the blue/yellow (joined) cables. Pin 2 is listed on this guide (https://www.scribd.com/doc/120489923/VW ... al-ENG-GER#) as ‘external mute’ an this is what puts it into ‘phone’ mode. The unit won’t power up without this pin being powered.
I have tried removing the pin once the unit is on and it stays on and works, problem is, when I switch it off it won’t come back on (unless I reconnect pin 2).
Marbles...lost.
Marbles...lost.
blakey
How's it currently wired up? You may need to repin the plug for it to work.
Logic would suggest it should be as below:
Pin 8 - Ground - Brown
Pins 5 & 7 Permanent 12v - Yellow & White (possibly a loop wire needed)
Pin 4 - Ignition switched feed - Red
Member No. 1455
Member No. 1455
Fresco3000
It works atm but once I switch it off it’s back to square one.
I ’m Fairly confident the standard wiring is in the right place.
Definitely down to security or memory, something daft that it needs to sync/start.
I have to connect the ‘phone’ or ‘external mute’ pin for a moment then disconnect it to enter the security code. Bingo, we have sound, but when I switch it off it won’t switch on again.
Fresco3000
Seems the switched live is dead.
If I connect all the pins that require power to the permanent it works fine.
Question, there are three wires that require a live connection, as long as I switch the stereo off, will this be okay to run with?
blakey
Yes
As long as it is on a fused circuit, which the original stereo wiring is, you're ok. Just make sure any loop wires are correctly terminated/insulated and secure.
Member No. 1455
Member No. 1455
Fresco3000
Cool,
Thanks Blakey!
Thanks Blakey!
Fresco3000
Picked up a set of Alpine-4625s 2 way speakers, one fitted straight in the other bulges a little.
Have found a bluetooth adapter for the Gamma stereo, expecting it next week.
Thanks for all the guidance folks, when I get bluetooth sorted I'll post a simple recap with photos in case anyone else needs the info.
