Soooo found 5 minutes for some fun today and so went about spraying the repair for the rear light...
Unfortunately the more seal I removed the more I realised it needs more time on it so did a little rust stop and put it back. I will be buying a new seal. Before I do, did I see a SR special deal for these boot seals somewhere??? Cheaper than heritage?
Was fed up after breaking the cap on passenger side wiper when I first got the car, so I removed with the intention of painting... what's the worst that could happen as I would like to replace anyway
Took a while to dry
Was so enthusiastic I wanted spray some nuts, until I realised the rattle can had issues!
Dipped rather than sprayed
While the hammerite was out
Front
And rear
But I only took a picture of the finished rear?
Was fed up with my rusty gear stick so again with the hammerite
Bet that surprised you?
I must have spent half a cup of tea contemplating about the colour choice... it is still white but the debate rages on (in my head)...
Have spent a lot of time in the week trying to make sense of the dash wiring, but with it all buttoned up for now I put the mats in after their stint in the boot. Not before making them functional again
Even treated the interior
With a few minutes of light remaining I dove into the bay to fine something to do...
Thought this would be the best place to start to find a dodgy connection. Not much found but another part of the scirocco is slightly cleaner and with rejuvenated nuts, bolts and washers I'm confident the problem isn't there!
Where's the fridge [emoji481]...
