rocker cover
duggers
Re: rocker cover
Post by duggers »
The nuts should only be done up to 10nm. Most leaks are as a result of over tightened nuts/bolts causing cam cover warping or too much gasket compression.
Membership # 432
Re: rocker cover
duggers wrote: Most leaks are as a result of over tightened nuts/bolts causing cam cover warping or too much gasket compression.
and as a result of the reinforcing strips missing.
i use the cap head bolts so you can be sure the cover is torqued all the way down and not sat on the stud shoulders.
