mk1 golf gti engine on pierburg
Re: mk1 golf gti engine on pierburg
I guess if you block the water outlet on the carb manifold and cut the pipe off the back of the Injection head you should be able to fit it?
Or maybe find an older injection head without the air shroud injectors.
