91 ABF Track Project........Six weeks in
Re: Hubbub
Post by mr.brown »
Day 14
Had to give up on the backplate bolts. Oil, heat and bolt extractors all failed so it was back to old faithful - the angle grinder. Stuck a wire brush on and gave them a bit of a clean once the backplates were off. I'll be running without backplates hence didn't attempt to remove the studs.
Re: Hubble, bubble, toil and trouble
Post by mr.brown »
Day 16
Talking of angle grinders, I'll have to smooth this bit off - bit jagged edgedy
And who has ever removed their seats and found it clean. Not me..
Re: Holey pipes Batman!
Post by mr.brown »
Day 17
So, finally got round to installing a new freeze plug and putting hose clamps on the new radiator hoses. Put some (cheap) coolant in as a test and was greeted with a familiar sound - drip,drip,drip...
It turns out there's a hole in the metal coolant pipe on the side of the engine. The part is £61 from VW but is "backordered" with no expected date :-(
Is the metal pipe like the one fitted to a 8 valve engine?
If so £30.74 and in stock! (other places may sell it)
http://www.gsfcarparts.com/179vg0020
Post by mr.brown »
mark1gls wrote:Is the metal pipe like the one fitted to a 8 valve engine?
Similar but different. However, I may have to resort to getting one like the above and "modifying" it.
Luckily I have a complete working donor car - hopefully the pipe on that one is in better condition.
*It turns out that the 2.0 8v (AGG) engine pipe may be the same but with different fixings - GSF part no 179VG0060.
Re: Definitely a Winter project
Post by mr.brown »
Day 18
There's snow way anything's getting done today...
Post by mr.brown »
Day 20
So, it turns out that the metal pipe for the ABF is no longer available. However, thanks to folks at CGTI, I learned that the AGG (2.0 8v ml3 Golf) pipe is very similar. It needs a small pipe blocking off (bottom left) and the mounting point doesn't match up (centre of pic) but essentially its the correct length and shape.
Re: Them 'bones
Post by mr.brown »
Day 23
No outdoorsy stuff so I'm looking for jobs I can do indoors. The p.o. very kindly gave me some Febi goodies he'd been intending to fit -
I'd already removed the old 'bones and so swapped the Powerflex bushes over. Refitted with liberal dose of copper grease -
Re: Them 'bones
Post by mr.brown »
Day 25
Wheel bearing housings made to look a bit more presentable and postie brought some goodies. Still waiting on other bits so I can start re-assembling the front suspension and the cooling system.
Re: Soundproofing? No ta(r)
Post by mr.brown »
Day 25 pt2
Bored + new heatgun =
And for future reference - don't bother. Seriously. All the crap I've removed is only 2.5kg. And now I have to grind/clean all the remaining crap, primer and then spray it. Sooooo not worth it.
Re: 91 ABF Track Project. Day 27 - Brace yourselves
Post by mr.brown »
Day 27
Lot's of puzzle pieces turned up today.
I'm sure I ordered black :dunno:
The first one came two weeks ago but it took ages to find another matching one
Rusty dan
Post by Rusty dan »
Looking good sean and do you have any plans with the ABF tuning wise?
I get the pointless sealant removal so I went one step further and intoxicated myself with a fumes from the plasma cutter and voila! No more floors lol :focus:
insanecreations.net
Post by mr.brown »
Rusty dan wrote:Looking good sean and do you have any plans with the ABF tuning wise?
No tuning plans with this engine but I do have a spare so who knows?....
If I had a plasma cutter I'd probably cut the car in half!
Post by mr.brown »
Day 33
3 hour round trip to get my new hubs and bearings pressed in. Mmm...shiny. Also, trial fit of Epytec adaptors for G60 brakes - and sneak peek of coilovers that cost more than the car!
Grooved/drilled discs from my Ibiza - got to love VAG parts compatibility
New wishbones, balljoints and strut brace also on
Bill
Re: 91 ABF Track Project........Day 33 - Shiny and not so shiny
Post by Bill »
Looking good, where did you get the strut brace from.
