Jason
78 race shell hill climb/ bonneville
Re: 78 race shell hill climb/ bonneville
Is this you Nigel? Pretty sure I saw that IC on my Facebook feed this morning!
Jason
Jason
Epic build. Need some pics of the car!
Yes it's me Jason
If people in Oregon or Washington
knew what I was building I would be
more worried about thieves and naysayers.
This is top secret but do any of you remember Kevin black?
He had the 16v turbo mk1 scirocco. I found one of his friends
Who bought the drag car, he is selling me the orange crush turbo
Type in orange crush scirocco on YouTube
It's a t4 t61 .70 a/r turbo by Turbonetics.
He had brand new custom turbines built to upgrade it and never installed them
Which I will also get with turbo.
The new turbines installed would make it a t4 t66 .82 a/r Turbonetics (600-1000hp)
I've made a deal to get the turbo, extra turbines,50mmwastegate, oil feed lines, manual boost controller,
I'm gonna try and get his Vw motorsports steering wheel too
I picked up a new water pump with metal impeller
Some new digi1 injector cups until I ditch the rocco intake
An optima battery
K&n hp3001 is the only oil filters I use from a diesel rabbit application
And I got a t3 to t4 adapter out of cast iron
Here are pics of the turbo and turbines from the crush
An optima battery
There are pics of it on the first pageMr Funk wrote:Epic build. Need some pics of the car!
I'll get more when it's sunny
It still needs windows, pedal cluster, 02a mounts, 02a or 02j trans,
Shift box, eurovan actuator, I also need another seat,
need to run brake lines, need to run fuel lines,
Swap in wiring for entire car
When I'm done this will be street legal race car so it can be driven
To shows and the track
And I need 2 more calipers from a g60.
Also need to find a nice radiator
Less than 26" wide & all metal
No joke I'm building a Ferrari,lambo killer :)
I raced a zr1 a few years ago at rolling speed ,
i would like a rematch when I'm done
All right you neglecting bastards
Change of plans I picked up an 2.0 ABA block
Compression is now at 8:1 and engine is 200 more ccs
With some forged parts
Motor is ready to drop in
And plugins together
Installed:
Brake lines
Brake calipers
Booster
Master cylinder
Cluster
Steering assembly
Interior wiring
Engine wiring
Poly bushings & mounts pressed/installed everywhere
All glass in & rubber
Dash in around roll bars
Motor mounts installed
16v 2.0 intermediate shaft and oil pump installed
Repaired threads on oil pan flange
New seals rear main etc
New throw out bearing
Can't remember it all
Just need green giant injectors and piping for intercooler
And a few random cylinder head sensors
Installed:
Brake lines
Brake calipers
Booster
Master cylinder
Cluster
Steering assembly
Interior wiring
Engine wiring
Engine is in the car
Car is wired from tail lights to dash to engine bay and headlights
All glass except doors to do list, they have been rust proofed and prepped
Intercooler plumbed
Turbo in the mail engine bay wired
New block 2.0 aba some forged internals stock
Old 1.8 head 16v
G60 mls headgasket
2.0 16v oil pump and intermediate shaft
1.8t Kevlar timing belt
G60 throttle body
Rci fuel cell
Bbm billet fuel rail
2.5 intercooler tubing
3" stainless exhaust and down pipe (just got ss mandrel bend 3" I need argon to finish it
Intercooler plumbed
Old 1.8 head 16v
G60 mls headgasket
G60 throttle body
Rci fuel cell
Vr6 Clutch installed
Shift box g60
Trans g60
Tdi flywheel
Custom motor mounts zinc plated
Poly inserts into new hd mounts all around
Obd1 g60 computer chip sns stg 5
To do:
Hydraulic clutch conversion on pedal drill hole in fire wall create brace
Find #42 injectors
Front main crank timing seal
Cam shaft timing seal
Install door skins and put in windows
Plumb oil lines and vacuum lines to wastegate and turbo etc
Plug in more stuff
Battery is installed and CD player & system
Pictures:
http://forums.vwvortex.com/showthread.p ... uild/page2
Shift box g60
Trans g60
Tdi flywheel
To do:
Find #42 injectors
Plug in more stuff
Pictures:
Also installed arp head studs to 85 ft lbs
Tdi Alternator is installed too
Installed time serts in oil pan threads
Head coolant side to heater core will be blocked reducing coolant hoses
And chance of leaks
Intercooler is mounted to core support barely out of the way
Of the massive alternator
And chance of leaks
