New Sirocco owner and needing help
Re: New Sirocco owner and needing help
If you check the cars breaking section, someone is breaking a 1992 injection - it might be easier to take the complete column, door handles and boot lock from that car. Or if you've got any car breakers near you, the parts from any 85-on mk1 Golf cabriolet will be the same.
Did I imagine it or are you from the north east? If you are there is a huge VW breakers in Gateshead called Vee Dubs. There is also an excellent VW specialist in Newcastle called Addington Motors 0191 2761900, used them for 25 years now.
I am from the north east im in north shields.
i will check out addington motors and vee dubs
Thanks for the info
Phil
Thanks for the info
Phil
