Bushy Problem
pajsh
Bushy Problem
Post by pajsh »
I spent part of last weekend restoring and painting my Eibach ARB's not really thinking too much about whether they were standard or not.
Looking around for some replacement bushes I now realise they are much bigger than standard and I'm not sure now where I can get some replacements.
The front ARB I measured this morning as 22mm (standard 17mm) and the back as around 25mm (standard 20mm).
The inners I think I could re-use at a stretch but the outers are well knackered.
So, does anyone know where I can get 'Rocco Mk2 Eibach Poly front & rear ARB bushes from?
As you can see I have the originals so maybe it's not too far fetched an idea to mould my own with some casting plaster and some poly material.
Is that light at the end of the tunnel or a train coming the other way?
See my build thread here:- viewtopic.php?f=19&t=10466&start=75
Re: Bushy Problem
I see your problem, can't even use standard replacements.
I use bugpack but I don't think they'll help.
Awesome GTI/Demon Tweeks?
* Edit, moved to the right section
Birdy
Re: Bushy Problem
Post by Birdy »
Give C&R Enterprises a ring, they do the full range of powerflex/superpro/vibra technics and prothane bushes!
Found them really helpful when i replaced all of my suspension bushes last year
VW Scirocco 16V GTX, Kamei X1 and a half
pajsh
Re: Bushy Problem
Post by pajsh »
Thanks for that I will try them.
I was looking at Bugpack till I realised the ARB's are much bigger.
I will also trawl Fleabay as there seem to be plenty of people selling poly bushes.
I'm beginning to think I shouldn't have thrown the springs away too as I suspect they were upgraded too. :dunno:
MacColl
Re: Bushy Problem
Post by MacColl »
Try..
http://www.superflex.co.uk/
I believe they supply Crazy quiffs, I recall being very helpful on the phone.
Also these guys who do Polysport ones along with the above make..
http://www.rallydesign.co.uk/index.php? ... fkccc03vj6
