Whats this cable?
dozzum
Whats this cable?
Post by dozzum »
Whilst poking around looking for where my car is leaking from I noticed this cable behind the dash on the passenger side. I have highlighted it in some photos below, there is also one the same on the drivers side, it comes up from below the dash and goes through a hole in the pillar.
Cannot understand why there would be a cable running up there?
MacColl
Re: Whats this cable?
Post by MacColl »
Almost looks like the thickness of a drainage pipe for a sunroof.
Is it not part of the wiring to the interior light?
Has it had an alarm fitted from before? I've got a wire and sensor thing from an old alarm up that pillar.
dozzum
Post by dozzum »
Its definitely a cable of some sort, for some reason I hadn't thought of the interior light and yes it has had an alarm at some point in its past.
Can anyone confirm if it is the interior light? Seems a bit thick and why does it go up both sides as well though?
Does anyone know if it is possible for water to be leaking out of the pillar where the cable is coming through as there does not appear to be a grommet of any sort?
DT1
Post by DT1 »
dozzum wrote:...and why does it go up both sides as well though?
Each door has a switch. If you pop the interior light out and have a look at the wiring you will see that it goes both left and right.
mr.brown
Post by mr.brown »
They're the sunroof drain pipes. :good:
dozzum
Post by dozzum »
I thought they might be sunroof drain pipes but It doesnt make any sense as to where they are going, they appear to be going from behind the dash into the pillar.
Yet when I look in from the bonnet the sunroof drain pipes appear to go directly into the pillars without passing through the interior of the car?
MacColl
Post by MacColl »
When I stripped my Mk2 golf I found that there were potential screws that may snag the drainage pipes/drains from the sunroof. This might explain why they might be routed a certain way away from certain sharp points or obstructions.
Old Mac Rocco
Post by Old Mac Rocco »
The drain pipes I removed from my old B plate were a cream colour.
They come down the four pillars and out just behind the wheel arch section at each corner.
:bye:
what colour is the cable? can't make it out in the pic
dozzum
Post by dozzum »
Black
from memory, the wires from the door switches are brown with a white tracer (switched earth) but it could be the live feed to the light
