Have I knackered a temp sender?
Dutch GT
Post by Dutch GT »
Just swapped the water flange and an O ring to stop a leak on the bottom sender (black). I forgot coolant so filled with water to get some, then drained it off and also replaced the other two O rings whilst at it. I was a bit hasty and got hot water all over the top two senders. Now when I switch ignition on the temp guage goes straight to the top and the light flashes! If I disconnect the grey sender plug it obviously stops but won't read the temp.
Do I need a new one, and what is the name or part number?
Level of water is fine, don't think there is an air lock.
Also, looked like the previous owner put silicone around all 3 senders to stop the leak, peeled this off.
Cheers.
It's a GT 1.8 carb
PeteGLi
Re: Have I knackered a temp sender?
Post by PeteGLi »
What colour wire goes to the sender?
Dutch GT
Post by Dutch GT »
I'll have to check, pretty sure I didn't mix them up, the plastic is grey, nearest engine on top.
PeteGLi
Post by PeteGLi »
Dutch GT wrote:............., the plastic is grey, nearest engine on top.
Not quite sure what you mean.
I am not familiar with the sender layout on carbed cars as mine are all injection, but the coolant temp sender on mine is the one nearest the radiator.
The wire to it should be yellow/red.
See the FAQ - http://sciroccoregisterforum.co.uk/faq/ ... #more-1364
Dutch GT
Post by Dutch GT »
It's the grey one next to the red... which in this pic looks like it may have once been white!
ghost123uk
Post by ghost123uk »
Dutch GT wrote: I was a bit hasty and got hot water all over the top two senders.
Just thought I would pop in to say that the water won't have damaged the sensors.
PeteGLi
Post by PeteGLi »
It looks to me from your photo that your temp sender is the one on the bottom of the flange with the yellow/red wire running to it.
What colour wires run to the senders on the top of the flange?
Dutch GT
Post by Dutch GT »
I'm away from the car at the moment (it's the mr's car), so can't look at the colour... the photo is no help with all that oil. I think I'll just phone VW and describe where it is on the flange.
