What go-for-it1 said about the dished washers and, ideally, you should have the car's weight on its wheels before finally torquing up the bolts.
The tapped captive nut and the threaded portion of the bolt should be "dry" - do not use copperslip or other such stuff on it, although you can use it on the smooth portion of the bolt to prevent the bolt seizing to the metal sleeve in the wishbone bush.
Front lower strut brace fitting...
Re: Front lower strut brace fitting...
Yep, thankfully did get that bit right - there was another thread on here somewhere about making sure the threads were left clean and dry. I'll be taking the lot apart again this evening and refitting I think - I am making sure the weight of the car's on the wheels before I torque the bolts back up, primarily because I have no axle stands and I don't trust my jack!
- go-for-it1
No mate, I have a lower brace to fit but was worried it might all spring when the bolts are removed without the cars weight on them.wasted wrote:Nothing moved out of alignment, aside from the wishbones separating very slightly (the wheels were off the ground, so I just moved them back into place before fitting the bolts). Is that important?
Rob
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
Ah right - no, it was all fine actually. Shouldn't be a problem ;)
rocco balboa
if fitting a lower strut brace is the anti-roll bar then not needed really as the brace takes over in effect. True or not so ?
Tim_R
They do 2 different things. The strut brace stops the wishbone front mounting points flexing under load whereas the anti roll bar links the wishbones to each other to help reduce body roll under cornering.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
