Removing mk1 clocks?
Rich_Rocco
Post by Rich_Rocco »
Im pretty sure that this is going to sound like a really silly question but...
how do i go about removing the clocks in my mk1?
im replacing my broken speedo cable and cant work out how to remove the clocks :oops:
i cant see any screws etc and dont want to start pulling things at random incase i break something.
many thanks in advance
If it's got tits or tyres it's trouble but I always go back for more.
PeteGLi
Re: Removing mk1 clocks?
Post by PeteGLi »
Take your radio out if you have one, and you should see a screw through a bracket into the rev counter casing. Once you have removed the screw, the whole console should pull out, but you might want to disconnect the wiring to the back first.
I think you can remove the speedo cable though, without taking the clocks out.
The Autoad
Post by The Autoad »
PeteGLi wrote:I think you can remove the speedo cable though, without taking the clocks out.
Yes you can, reach up under the dash and locate the speedo cable to unscrew- it is a doddle.
Rich_Rocco
thanks for the help chaps
very much appreciated :hugegrin:
