Have really tried to spin the tyres to check the tractions to no avail. The clutch was supposed to have been changed 3 moths ago ? also when in gear give it a bit of welly slips like mad, back off a bit and away we go. so any ideas am a bit stumped with out taking the lot apart
WeirdClutch
WeirdClutch
Ok had Jeff 5 weeks now, never noticed this problem before as have been gentle untill all bits were checked and serviced. So out for a little spin we went.
Tim_R
Re: WeirdClutch
What's the clutch cable adjustment like? If that's ok then it sounds like the crankshaft oil seal is weeping and its getting onto the flywheel and friction plate.
Mine did it when I first bought it, some days it would slip badly, other days would be fine.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
Re: WeirdClutch
Thanks Tim , thats sounds about right. Well bring on the spring and will tackle the issue as its not bothering me loads at the moment
