door window seals???? are they still available?
hey folks, as above i am looking to get a new set of window seals, preferably the whole set if possible?
A. are they still available???
B. How much?
C. where can i get them?
Thanks folks!
B. How much?
Thanks folks!
Re: door window seals???? are they still available?
If you get the part numbers go and check www.vwheritage.co.uk I'd be interested too as the outer scraper on mine bit manky and wouldn't mind replacing them!
found them on there now, quite...... expensive, scrapers just shy of £30 each, felt ones roughly £50 each!!!! ouch ouch ouch!!! think i will have to get the scrapers now, get the felts another time!
part numbers for you mate
Left : 533 873 473
Right : 533 873 474
Left : 533 873 473
Right : 533 873 474
i would advise that you buy a left side on ASAP..... according to VWheritage they are NLA (no longer available)
Cheers sir, is that the outside scrapper that goes the whole way around the window? £30 not that bad if it is
no, the scraper is seperate, the window seals seem to be in 3 bits, the scrapers, felt seals that go along the back and top of the window, and another felt seal that goes down the metal 1/4 light seperator
Think that is the bit I need then, runs from 1/4 light to door post?
Hi guys
sorry for the eavesdrop
I lost my exterior seal that runs along the bottom of the window
basicaly sits where the window winds down into the door and stops water from pouring into the door
is that what you mean when you say scraper?
I just looked on vw heritage but couldn't find the part
hope i have not missed the boat again
don't really want to drive around with gaffer tape stuck to the door
would appreciate your help and advice
Ade
Ade
Yes, that's the scraper moulding. I bought mine for the Storm from VW Heritage, I rang them and they searched around for them, I think they cost me £51 including delivery. Worth giving them a call and speaking to a person!
The idea of the forum is that people can AND are suposed to eavesdrop and offer opinions and advice!parch wrote:Hi guys
Ade
If you go onto VW Heritage and enter the part number they tend to come up with the part, or thats what i have found, they also have rear number plate light covers (the ones that are impossible to get ahold of nowadays!)
