Gearknob?
haddock_n_chips
Gearknob?
Post by haddock_n_chips »
Mines split, does it just screw off? tried gently to screw off but didnt budge
dont wanna use too much force as dont wanna end up with no knob ;) :swoon:
millsy20
Re: Gearknob?
Post by millsy20 »
yes should just screw off. You might need to put a bit of force behind it tho.
1991 Red Scirocco GT2-Soon to be GT2 16v
2010 MK3 Scirocco GT TDi 140 for daily duties
haddock_n_chips
Re: Gearknob?
ta,
ordered a new one
just had to check wheteher ot was screw on or push on :-)
haddock_n_chips
Re: Gearknob?
f*ckin hell my typing is getting worse! :dash:
bluestreak56
Re: Gearknob?
Post by bluestreak56 »
I tried my best to get my one off today (to replace the gaiter) man its a stiff bugger! Will give it a proper go tomorrow..
Re: Gearknob?
Bring out the mole grips! :hugegrin:
Ashrocco
Re: Gearknob?
Post by Ashrocco »
You must be gentle when grabbing your knob, I twisted mine too hard and it fell off. :blush:
I replaced with an 8 ball :cool:
Ash
Re: Gearknob?
It just needs a real man's grip to get off, a bit like the tops off a jar!
bluestreak56
Re: Gearknob?
Ian when you get down to London ill ask you to try and get it off.
I tried for about 30 mins today just seemed to damage if anything!!
Re: Gearknob?
I'm not taking the p***, but you are unscrewing anti-clockwise? I have a big set of molegrips, shift anything!!!
bluestreak56
Re: Gearknob?
Yep anti-clockwise - I tried using a large set of mole grips but they damage the leather and slide around it also...
Re: Gearknob?
How expensive is the existing knob? Worth buying a new one?
bluestreak56
Re: Gearknob?
about a tenner I reckon - could possibly get one to to match the style im doing but wouldnt be original then..
Re: Gearknob?
Perhaps someone glued it on when they bought one of those hand brake locks before you owed the car. The lock used to fit to the hand brake and the gearstick and they used to come with some glue to stop you undoing the gear knob and removing the lock. Might explain why you cant undo the gear knob..
Re: Gearknob?
Grind from underneatht he knob. Bloody thing was too long anyway
