Question-Rear bench seat from a mk2 2 door Golf
markh
Is it anywhere near likely to fit in a MK2 Rocco with a bit of fettling ?
Re: Question-Rear bench seat from a mk2 2 door Golf
Not 100% sure, but id thought it may be wider and higher than a roccos.
markh
monzajake wrote:Not 100% sure, but id thought it may be wider and higher than a roccos.
That what i thought Jake, just wondered if anyone had actually managed to convert one to fit.
Mark found this, granted its about fitting a corrado seat in a golf, but i have no doubt the principles are the same, ie changes to look out for-
http://www.matey-matey.com/corrado_seat ... sion.shtml
I've got a set of raddo rear seats minus the arm rest just sitting if you want them
