Put my battery in the boot
MrD
Post by MrD »
Went and got a marine grade battery box the other day,connections on the top,and a couple of fag lighter sockets,bolted to the rear bench,all the earth's in the front have been grounded,to the battery tray,then using the middle rear belt point in the rear.as a grounding point.In the back.
Using 4awg gauge cable,which is what I ran my power amp on.
Effects are much brighter headlights,and my rev limiter seems to have stopped working,car feels much more lively.
Went out in it this eve,pulled over and asked my mate for directions to his new place,turned it off so I could hear him,went to turn it back on and nothing ! Had a bit of a panic,until I found that I had left the fuse in the main power lead,had blown that drawing current to start it,stuck a bit of metal bar in,and it's been fine,got some sorting out to do tomorrow,will bung some pics up.
Can tell the battery is not up front in the handling department too,really was not expecting to make so much difference
wassell
Re: Put my battery in the boot
Post by wassell »
handling aside, could the improvement on the battery power not be linked to the new cables you have used? dont mean to piss on your bonfire, just curoius :0
Wassell
MrD wrote:I found that I had left the fuse in the main power lead,had blown that drawing current to start it,stuck a bit of metal bar in,and it's been fine
definately needs a fuse on a cable run that long, and as close to the battery as possible
MrD
Post by MrD »
Yeah think I am going to take the fuse holder from the front,where it was close too the battery,and move it in the back,think it was a big hefty one that I blew.just weird how it fired up on the drive at home ok,and then when I stopped and turned it off it popped it.
Didn't get chance to get out there over the weekend,but will have another tinker when I get back from my job this morn.
how have you connected the +ve?
MrD
Post by MrD »
The fuse it blew was a 60 amp !! I just connected all the positive connections to the cable that was for my amp,all the negative connections are earthed on the battery tray,via a large blot and washer,holding the clamp down..
Some pics,the battery box has 4 bolts through the ply,and the body,and large washers,battery lid is held down with the metal strap,going to be doing a bit more to this,as I don't want it coming free if I have a prang..
Still need some tidying up,when I get time...
MrD
Post by MrD »
Went for a blast and the limiter seems to be working again,not sure what happened there...
MrD wrote:The fuse it blew was a 60 amp !!
it will do. think about it, if you've got a 90A alternator, and you just started it, then there's going to be not far off 90A going to the battery, albeit only for a short time. and a trousers more than that being drawn when you actually start the engine - that's why you see things like "600A starting power" written on your battery
jbo
Post by jbo »
He's right, you dont run a fuse on this. Good luck finding a 600a fuse :hugegrin: The original circuit doesnty have one for the same reason. Just make sure you hav instaleld the wire away from anythgin that coudl split it and short it out and youll be fine.
I wouldnt mind tryign the same thign myself. Poss welding in battery tray....
jbo wrote:He's right, you dont run a fuse on this.
whoa! i didn't say don't put a fuse in it. a cable that size and length definately needs a fuse in it. if it chafes on anything and shorts out, it will be byebye car very quickly without a fuse.
jbo
Post by jbo »
Where the hell would you get a fuse that size?! Or woudl it be more of a breaker?
scrappy would be my first port of call probably. go plundering something that doesn't have it's battery under the bonnet. transits have the battery under the seat, and they have the -ve connected to the chassis via a "fuseable link". mercs have batteries under the rear seat or in the boot, so they must have something similar. you can buy 600A fuses, but they ain't cheap
jbo
Post by jbo »
Nate wrote:scrappy would be my first port of call probably. go plundering something that doesn't have it's battery under the bonnet. transits have the battery under the seat, and they have the -ve connected to the chassis via a "fuseable link". mercs have batteries under the rear seat or in the boot, so they must have something similar. you can buy 600A fuses, but they ain't cheap
Ahh ok cool. Sorry for gettign it wrong. i didnt know sucha thign existed! :blush:
