Knocking under turning
When turning hard at slow speeds, usually at full lock, there is a knocking noise coming from the floor. CV's seem to be alright, as well as balljoints and trackrod ends. Wondered if this was a common fault or if anyone has had this before?
- go-for-it1
Re: Knocking under turning
Worn CV's normally the culprit for knocking on full lock. Don't know how you determine that the CV's seem to be alright. It could also be the front spring is not seated correctly.
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
I would agree, CV joint.
