so got to thinking of a replacement not a mk1 as would not be the same as the 77
so think mk2 vr6 (may be turbo as i like power
as i see it a vr6 engine box in too the mk2
will needed to be done
.engine 3 mount points drivers side rear passages gearbox mount front gearbox/engine mount which will be cut from vr6 sub frame then welded to scriocco and extra metal the make stronger as well as the front scirocco beam mounting point
. 100mm drive shafts
.280mm brakes (still have my brake kits from the last lot i got made for here
16v golf disc rear scirocco 16v handbrake cables master cylinder from mk2 golf 16v
.make exhaust system 2.5in singe tail pipe 2 boxes
.cooling passat rad ?
. unit oil cooler unit ?
.fit wiring from the vr6 golf to scirocco i fit the full loom same as done to the mk 1g60
coil overs fitting uprated bushes all round
lower strut bars frame making
sound easy when i put it in too words
any thing you think i missing out
