First thanks all for your input, greatly appreciated.
1 MacColl,
Phoned A+L Paints and the cans are £10.40 per 400 ml can, cheaper and bigger than Halfords (£13.99 per 300ml) but the same price if I have to go for them (petrol).
If you are planning a visit could you pick up two cans for me and I'll pay you when you get here.
A scan through your mag would be beneficial as well.
2 Ian,
I thought a tad expensive as well but it is the old story "you get what you pay for".
He did say that that was the top price and if I had it prepared to a good standard it would be less.
I have filled, sanded and primed the door and have given it a couple of coats of silver paint prior to rubbing down again.
3 Nate,
I had seen this pic before but never thought anything about the door til you pointed it out.
Just thought it was reflections / shadows.
The darker panel on yours is the bit I want to touch up, ie the bit below the rubber strip to the bottom but mine has the rubber body mould along the bottom so that will be undrecover.
Maybe he did say "blend" but by this time I was crawling about on the floor looking for my walking stick after the initial shock of £240.00 had left me legless.
4 jxp,
This worries me a bit as well as after rechecking paint code in the boot I noticed it was LP7Y so I am now re-tracing my steps to see if I have been looking for the right paint.
Thanks to all for your comments.
Much apprecaited.
I HAVE CHANGED THE HEADING TO THE CORRECT PAINT CODE LP7Y
