does any one happen to know what part number i should go for? there is a choice of a few?
its for a 93 scala, dx engine.
any help would be great!
thanks
Go to the dealer and they will sell you the rubber replacement rocker gasket set, you will need to change the studs but they come with the kit.
I paid £17!
ianaudia4 wrote:Go to the dealer and they will sell you the rubber replacement rocker gasket set, you will need to change the studs but they come with the kit.
I paid £17!
erm i think you may be thinking of camshaft, i was after crankshaft! lol thanks all the same tho!
