but with the rocco running lumpier than my attempts at mashed potatoes it became time to get back to it.
I'm sure it is an air leak somewhere so I have decided to sort the cda induction kit while I'm taking the manifold off to sort the gaskets and make it air tight.
But in order to fit this
in place of the old airbox I have to get rid of that huge fan motor that sticks into the bay so the best way to do that is with a slimline rad fan but I didn't want to lose the cooling advantage of the fan shroud so I have fitted the fan in the original shroud.
I went for an 11" fan but I think I will redo it with a 12" and a bit of trimming.
got a bit carried away with getting it fitted so forgot to get a pic before I put it back in but you can see the clearance is much better without the motor sticking out
hopefully I will get the rest swapped over tomorrow and will put some more pics up.
