Stem Seals
T0M
Stem Seals
Post by T0M »
Hello there,
Just wondering how you get the valve stem seals off a DX head. little buggers seem to be in there pretty tight. started pulling them out with pliers but just started ripping rubber instead of getting them out. cheers, Tom
88' Scirocco GTX
92' Polo G40
Funky Diver
Re: Stem Seals
Post by Funky Diver »
REplied in your project thread... but long nose plier... on the outside of hte seals (so the metal bit) twist and pull. I did the same first time I removed them, shredded the plastic / rubber... but the twist/pull method gets them off without issue.
MikeH
Re: Stem Seals
Post by MikeH »
You can get proper stem seal pliers, but as above, try to grip the metal ring, not the rubber.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
T0M
Re: Stem Seals
Post by T0M »
got 'em. thanks!
88' Scirocco GTX
92' Polo G40
