White gunk on oil filler cap??
mikey360
Post by mikey360 »
Right, for a while now every time I check my oil there's a white thick goo over the top of the oil filler cap.
At first I thought it was the head gasket but after carrying out a compression test, everything fine.
Its had about 4 oil changes since I've had it so its not as if the oil is old or something.
And I recently fitted a new oil cooler to it so I don't think any water could be getting into the oil
I spoke to a mechanical friend of mine and he said if I'm doing a lot of short journeys (which I do) then its just condensation building up...
Is this true? Or is there something else I need to look for??
Cheers :beers:
2002 BMW 325ci
1985 XT350 (in bits)
1991 Yamaha virago 535
Jay4424
Re: White gunk on oil filler cap??
Post by Jay4424 »
true
same happen with motorbike with those would start it and run it for 10 mintues once a week/fortnight during the winter to "preserve it" ...its much better to leave it well alone!
but in your case, either go for a bigger drive every so often, or stick a heater in the sum :hehe:
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
DT1
Post by DT1 »
Happens all the time, don't worry. :good:
mikey360
Post by mikey360 »
Cheers guys, a 2nd opinion never hurts! :hugegrin: :beers:
2002 BMW 325ci
mikey360 wrote:I spoke to a mechanical friend of mine and he said if I'm doing a lot of short journeys (which I do) then its just condensation building up...
yup, very common. if you're super paranoid, you could get one of these to double check http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0648899970
you put it in the top of the expansion bottle and the liquid changes colour in the presence of exhaust gas
