Click the link for gear box codes.
http://www.brokevw.com/ Manly 020 5 speed here
http://www.4crawler.com/Diesel/VW_020_t ... sion.shtml 4 & 5 speed codes 020
I found these sites usefull, for the engine conversions ive carried out.
Gear box codes 020
- filmidget
Re: Gear box codes 020
Anywhere we can host the excel file I wrote to compare gearbox ratios/speeds@revs/rev drops/etc?
It's not wonderful, but it works.
- The Autoad
fil, skoot it over and i'll lash it up on the faq
- Funky Diver
And Gear Ratios
Thought I'd revisit this thread as I've found a LOT of info over the last week or so.
Long story short... figuring out whether to use my original 020 from my 1.8GT or the Mk3 Golf GTi box. (the GTi box has hall effect speed sensor rather than the cable (which is what I want ;))
http://www.clubgti.com/forum/showthread.php?t=115595 - has a LOT of info re: gearing ratios for varying boxes. It also has the part numbers for hte speedo drive wheel.
http://www.gearboxman.co.uk/download/gearspeeds.v2.xls - if you want to work out your gearing ratio - speed on various tyres, or are looking to change cogs, this should help you decide which way to go.
Re: And Gear Ratios
Doesnt the electric speedo sensor come off? im sure you can instal this on your gt box. are you installing a certain kind of clocks by any chance?Funky Diver wrote:Thought I'd revisit this thread as I've found a LOT of info over the last week or so.
- Funky Diver
I sure am... but not what you're thinking, lol.
The brains behind my clocks
Got most of the schematics out of hte way now, just need to get the soldering done, and a bit of testing once it's all running again.
The pic isn't working fella.Funky Diver wrote:I sure am... but not what you're thinking, lol.
The brains behind my clocks![]()
I'm not sure the hall sender type can be put on the 020. If you need the part number have a search for the digi fizz guide. I know that isn't what you are using but the part will be the same.
Much easier fitting this that converting to cable change!
Jason
