Converting to kjet
Converting to kjet
Got an offer of a great engine but it's running kjet.
Could anyone tell me if it's a viable swap?
Re: Converting to kjet
what are you changing from Mr Funk?
Normal digi
MikeH
What engine is it. What car is it going in?
Digi to Kjet would be a complete change of fuel system - everything except the tank and lift pump, and you might be able to keep or adapt the under-car pipes.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
Been talking to a guy that did it previously and it was just a dizzy and ancillAries change
? have you changed your lump dude ? couse if your still running the 1.8 inj your all ready k-jet..
Just seen your point there jake, I'm a moron.
Right, engine is currently the standard 1.8 kjet injection and the engine going in is a mates 1.8 porter and cammed digi jetta lump. My head is cracked and as he's going g60 he's offered his complete lump for less than it would cost to get another k head and have it played with hence why I was asking about whether it's worth the effort
Been piloting a course for the past couple of weeks so my heeed has been somewhat occupied
MikeH
So it's a Digi engine going in a Kjet car?
You can run them on Kjet too - the injector inserts may or may not fit down the digi injector bores. I had to go with the brass part of the insert only, and knock the 'top hats' off the Kjet injectors to fit down the digi injector bores.
You need to fit your kjet dizzy to it, and manifolds from your current engine. I think that's about it.
Is it based on a 1.8 or a 2.0 block?
Is this the same engine Ben is asking about on CGTI?
Either that, or Megasquirt it (FTW).
Yeah, that's mine.
We'd gone through and cleaned everything down then discovered a lovely hairline crack. A massive pisser and no mistake.
Right now mr funk has confused the crap out of everyone ill chime in
the car is kjet the engine is digi as already said i spoke with mike on clubgti and it looks pretty straight forward to be fair albeit the injector inserts could throw up a few issues
the other issues is the involvement of mr funk who im sure will admit himself he shouldnt get involved it makes things hard
as much as id love to fit megasquirt im not sure the car is ready for that step just yet
It's true.
Interiors, wheels, stereos and other shiny gubbins I can do. Actual relevant mechanics I am stumped on
MikeH
Having fitted MS to mine, it will make a big difference to the power achieved with the modded engine. Still be a good package on Kjet though, especially if you fit a 16v WUR and fiddle with the fuelling to get it running rich enough.
MikeH
One more thing - it was also suggested to me that the kjet injectors would fit ok in the digi inserts. I didn't try it, as I had spares, but might be worth a look.
ill check the inserts before i start messing around just incase they do fit of sorts
Mike yours looked pretty strong on the rollers be interesting to see it on another set of rollers to see what they say the bhp
there is another rr day at amd in essex at the end of this month
