I have added some gauges to the car and used some second hand sensors. One is for the oil pressure, and the other oil temperature. When these are unplugged the buzzing and flashing still occurs on the dash.
1. I drove all the way to Cosford, no problem, drove home started to buzz
2. I drove all the way to Beaulie and it was fine no problem
3. I drove 2 minutes down the road and it started. Turn the engine off it goes away. Go above 2000 rpm and it starts again.
The car drives really nice and idles where it shoudl, just under 1000 and no juddering. Smooth thorugh gears and starts and turns of ok.
Is this a dodgy sensor, or do you think I have a real problem?
Has anyone had this before and did you have a solution?
