Hello all,
My rear wiper seems to have a mind of it's own. It rarely comes on, but then only makes five or so sweeps and then stops. The rear screen fluid squirter seems to work just fine. Any ideas?
Rear wiper rarely works
bensspares
Re: Rear wiper rarely works
check the wires from the tailgate going through to the body in top left hand corner
ben
ben
Try another relay as well.
All. Thanks for the replies. Turned out to be the relay. All works fine now. Just in case someone needs the same part it's GSF part number 935VG0150 WASH/WIPE RELAY-REAR.ianaudia4 wrote:Try another relay as well.
I also found this site useful to navigate the fusebox/relays:
http://www.vintagewatercooleds.com/tech ... se-panels/
Thanks.
1986 GT S
I was always told to start with the basics first, glad it is now sorted for you.
