Hi all
Just in the thro's of trying to A) Make my sunroof work and B) Stop it leaking
I have searches but drawn a blank so does anyone have any decent pics or is there a disassembly guide anywhere?
It appears that the bit(s) in my wanted post HERE http://www.sciroccoregisterforum.co.uk/ ... f=6&t=6964 are hopefully the cause of it not working. I just cant quite fathom how assuming I can get hold of the broken part as to how it goes back together?
Haynes does show a picture. The bit that you have snapped is the tilt mechanism.
Where are you based, there may be someone close to you that could help as it is not the easiest of jobs to do single handed.
due to fitting a newly refurbed black sunroof trim i have just disassembled and then reassembled a factory roof using the haynes - it does take a while (three weather interrupted attempts.....) and you do have to be careful/patient.
Home from work & just put my bike away in the garage and found the haynes manual. Surprisingly there is quite a lot of info on the sunroof
So back to my wanted ad are those 2 parts still available from the stealers or is it a task of trying to find one in the breakers?
I was contemplating getting a couple of guide plates made out of steel, I'm mid stripping hte car at the mo' and figured this'd be the time to do it. Save getting the car back together and then having one snap on me.
For anyone that has replaced this part, is it flat plate?
ianaudia4 wrote:If you could wait until the weekend after next I could have a drive up and maybe give you a hand with your sunroof mate, 2 hands and all that!
Hi Ian
Not in any rush as while the weathers good I will still be using my bike and of course I need to source the parts first?
Will perhaps speak to someone about getting them made if I draw I blank in trying to find some
Hi Ian
Tony
And if you are changing the seal round the panel, make sure Ian cuts it the right length
