ianaudia4 wrote:Can highly recommend the Alpine 6x4's perfect fit in the original holes. You could put a dab of silicone in the badge holes and refit, good and easy fix.
Alpines fitted all round today - sound much better. Don't know if it's me being cackhanded but will have to work out a permanent solution re the rear speaker grilles not fitting properly due to speaker element sitting a little higher than standard, velcro strips methinks.
also tried one of the ebay headlamp looms - came with incorrect - for a mk2 scirocco - spot lamp connections and for the life of me I couldn't get to work properly, sides ok, dipped ok but reverted to sides only on main beam, seller refunded - still searching for a solution there. Who out there has a source for a completely 'plug in and it just bloody well works loom'?
back to headlamps by dickensian candle light..................
