What size are the standard front and rear speakers?
HotSoutheastWind
What size are the standard front and rear speakers please?
As you know i dont deviate from standard, but some of the speakers are a little tired in my Storm. I was planning on getting new ones all round (the same size so i can keep them under the original grilles, just really good quality ones).
What are the front and rear sizes please?
Cheers :)
Cheers :)
- Funky Diver
HotSoutheastWind
Re: What size are the standard front and rear speakers?
Perfect! Thanks mate - appreciated :)Funky Diver wrote:4" x 6" for both matey.
Alpine do some excellent replacements 150w approx £45
HotSoutheastWind
Nice, thanks Ian, ive always been happy with Alpine products in the past - i think ill be following your lead here. Cheers mate :)ianaudia4 wrote:Alpine do some excellent replacements 150w approx £45
HotSoutheastWind
- Funky Diver
So long as they're standard speaker size across the face and don't protrude too much, they should fit. There's plenty of depth to use behind the doors so no worries there.
HotSoutheastWind
Smashing mate cheers, much appreciated!!! :)
I changed both my cars speakers for Alpines, they fit behind the grills with no hassle.
HotSoutheastWind
Smashing - cheers Ian - Alpines it shall be!!! :)ianaudia4 wrote:I changed both my cars speakers for Alpines, they fit behind the grills with no hassle.
just be careful of 2 things:
1] central built in tweeters that stick out too much
2] some infinity stuff has a 1/2" lip sticking up round the edge which stops the grille going on
HotSoutheastWind
- Vonlard
I had the lip problem when I swapped mine and got tired of having them on show so I took the door panel off whipped the door pods off and fitted them to the back of the pod. had to trim up the door a bit so they would clear but is all hidden away now and looks stock
It was meant to be a cheep run around till I finished the Type 1, Now I have 2 projects and an obsession
61 Type 1 Gasser project
88 Scirocco GTX rolling project
DT1
Aren't they just glued on?
I had a set of speakers with them on and with a bit of careful pressure they just pop off.
rapidly followed by the cone, if you listen to loud music. eh? pardon?DT1 wrote:with a bit of careful pressure they just pop off.
