Weber Induction Kit Adapter
Funky Diver
Post by Funky Diver »
OK, so in the spirit of keeping things looking nice, is there such a one? I've seen a few odd looking adapters for Webers, including ram pipes, but not for hte standard Weber available.
Cheers,
Rich
Re: Weber Induction Kit Adapter
presumably for the 3234dtml? what are you wanting to sit on it?
how about the rubber gaitor from the air meter on a volvo 740, a length of polished stainless of suitable size and a cone filter on the end, with bracketry made to suit
Funky Diver
Nate wrote:presumably for the 3234dtml?
Yup...
I don't actually want to sit anything on it... except maybe a cone style filter on the front end of the induction tube :P
Thanks for that... will do some hunting round scrappy
the volvo has k-jet, same as the rocco, but rather biggerer. as i remember it, that gaitor would be just the right shape.
Funky Diver
hmmm... looked at the volvo pipe, not sure how it might fit.
There IS however a plenum (that just sounds like it should be covered in satin with red lace) kit for a 32/36 DGV.
Gonna give Peter a ring at WebCon on Monday t osee if it'll go on the 32/34. Woohooo, we could be onto a winner :D or we might not be. :shocking:
i've had a quick google, but can't find the bit i'm on about. looks very similar to the picture you put up, but the hole is round not oval
Funky Diver
The only google pictures I could find were of bits of pipe...
well it kinda is a bit of pipe, but it's roughly 4" diameter (same as the top of the carb) then had a tight 90 degree corner and becomes 2.5 inch ish pipe
Funky Diver
Kinda like this one
not really, no. i presume that's what the newer ones have. the ones i've worked on were all from the 1980s. i'll have another look......
ha! found it
http://i287.photobucket.com/albums/ll14 ... GP2810.jpg
fuel injected 240 and 740 series volvos
Funky Diver
ooooooh, aaaaaaaah... now that is sexy (for a bit of pipe, lol)
been quite a few years since i've interfered with a volvo, but from memory i think it will be more or less the right size.
