help with a 88 scarla injection plz
sciroccof529bax
Post by sciroccof529bax »
i changed the fuel filter the other day as the car was playing up since changing this the car drove about half my street then kept cutting out now it wont start and when it dose as soon as it gets warm it cuts out can anyone give me some advice as i feel like breaking the car at the min and the car is to clean and has to much history with it to do this many thanks rob
Re: help with a 88 scarla injection plz
Where you based mate?
sciroccof529bax
wolverhampton m8
It may sound like a bone question but is it fitted the right way?
sciroccof529bax
yh m8 we checked that the car was playing up b4 changing it it was like the ecselorator wasnt working and wen i put my foot down it went and then it was like i was bump starting it
Is the lift pump in the tank clogged?
sciroccof529bax
i hadnt even checked that m8 didnt no if they had one thanks for that m8 will try in the morning thanks again m8
No problem mate, no doubt others will put more advice on here as well.
sciroccof529bax
thanks alot m8 i took the lift pump out and tested it the petrol was just pumping out the side of the pump not the pipe cheers for your help
You are welcome mate.
