When starting
gearyboy
When starting
Post by gearyboy »
When starting my scirocco i have to give it a bit of gas, if i start the engine without, it turns over and dies. is this just a normal thing or is there something i should be looking at? Runs perfectly otherwise just needs a bit of throttle when starting.
Matt
wasted
Re: When starting
Post by wasted »
Pretty normal, I'd say. Starting from cold or hot?
Brunty
Re: When starting
Post by Brunty »
The instruction manual even states to use a small amount of throttle when starting the engine.
Brunty
Re: When starting
Brunty wrote:The instruction manual even states to use a small amount of throttle when starting the engine.
They did on the early versions (ie my Storm manual), the later manual says you shoukld not need to :!:
stu.gtx
Re: When starting
Post by stu.gtx »
If you stick some decent fuel system cleaner in it like slick 50 it might help. It did on mine a few years ago, worth changing the fuel filter too.
gearyboy
Re: When starting
Post by gearyboy »
wasted wrote:Pretty normal, I'd say. Starting from cold or hot?
mainly cold
gearyboy
Re: When starting
Post by gearyboy »
stu.gtx wrote:If you stick some decent fuel system cleaner in it like slick 50 it might help. It did on mine a few years ago, worth changing the fuel filter too.
cheers il give it a try
bluestreak56
Re: When starting
Post by bluestreak56 »
Is it an injection or carb?
If injection are the symptoms similar to this?:
http://www.sciroccoregisterforum.co.uk/ ... f=12&t=669
gearyboy
Re: When starting
Post by gearyboy »
bluestreak56 wrote:Is it an injection or carb?
Its injection, no its not like the above thread, just needs a bit of gas to start, once going its runs great. Without gas it starts and stops straight away. Ive only had the car two weeks but since posting this thread i have noticed it is cold start only
