Speedo cable
eamon1.3
Speedo cable
Post by eamon1.3 »
Think this is the right place, gear box end anyway.
Are injection and carbed cables different? Only ever worked on carbed ones and they had the normal drive gear on the end that came out of the box no problem. But taking the cable out of my 89 scala, well trying to, the gearbox end seems to be different and will not come out of the box!! Any ideas?
monzajake
Re: Speedo cable
Post by monzajake »
Im not 100 % sure but i think the cables are the same.
As for the ends ( i assume the cogend ) there are two different colours, red and white.
You need to match the right one with the right gear box or the speedo will be out.
eamon1.3
Re: Speedo cable
Post by eamon1.3 »
Would like to get the soeedo cable out of the box first
