Gear Linkage
JOH
Gear Linkage
Post by JOH »
Hi all,
I would like to tighten up the gear selection in my MK2 Scala injection as it has a fair amount of play (in addition to a nochety change from first to second).
Any suggestions?
Many thanks
essextom
Re: Gear Linkage
Post by essextom »
replace all the bushings using a kit like this.
https://www.classic-vw.co.uk/mk1-golf-5 ... 5436-p.asp
Re: Gear Linkage
Or at least just change the bushes which is what I did and that made a difference and it’s only just over £10 instead of the £70 in the link above….
https://www.ebay.co.uk/itm/361946594627 ... SwUuRgU0ro
To help gear chance from 1st the 2nd when cold new fully synthetic gearbox oil can help a lot.
A coupe of bottles of this stuff is what I’ve been using in both my cars.
https://www.eurocarparts.com/p/triple-q ... -522776282
Re: Gear Linkage
If you have a look at the linkage and get some one to change gear you should be able to see where the play is and then you can decide how far and how much you need to spend if it’s just the bushes and rods or other bits that need changing…
Re: Gear Linkage
Or just the bushes for under a £5…
https://www.ebay.co.uk/itm/144365219553 ... 1006617493
JOH
Re: Gear Linkage
Post by JOH »
Excellent, thanks all
