2 ½ Ltrs of that Dexron III goes in via the dipstick pipe.
The sump pan skid plate gets a lick of primer and black because, after nearly 40 years, why not? Incidentally, this also houses a simple throttle return spring when in place.
While the paint was drying, my clean(ish) OCD kicked in again... was idly thinking of firing up the Mrs's steam cleaner to see what it could do. However, a frying pan over the head would probably curtail any further use!
That's that job done, just need to double check the level when warm and top up carefully to the max mark.
Incidentally, I did try gently jacking the engine to see if I could get any more room for the wishbone bolt. Got about 5mm, no where near enough still. Hey ho.
