1991 mk2 scirocco GT2, sat in a scrapyard in Huntly in Aberdeenshire for about 15 years, initially only wanted a few parts off it for my ABF scirocco, but ended up taking away the whole car for £150!
Gonna try and sum up the first chapter of this build as briefly as i can, if anyone wants to see the full picture heavy build thread from ClubGTI heres the link
https://clubgti.com/forums/index.php?th ... st-2484201
Anyway... last year i finished building this ABF powered mk2 and its now my daily driver, learned heaps from this car as it was my first ever engine conversion, first ever repsray (took me a couple attempts as i was spraying it in my shed during a freezing scottish winter!).
i really enjoyed everything about the project and with the lockdowns etc coming into play in march i decided i would give my neglected parts shell a new life, as a fast road/track car!
Fully stripped it down, made my own spit and got going.
After a good couple months of welding i finally had a solid shell, welding included front and rear valance, front crash panel behind the valance, rear arch lips, drivers side full sill, various patches to the floor, welding around the filler neck area, lets just say the shell wasn't as solid as i remembered!
any unrequired brackets etc were removed, sunroof removed as was the sunroof tray, wanted this car to be as light as possible.
I bought a half stripped mk4 golf with an AGU 1.8t in it for the grand sum of £100, sold as much stuff as i could and after scrapping the shell i was up £300 with a full engine, loom etc
Bought a bunch of stuff for the engine from a gent local to me that was breaking his mk1 golf 1.8T, BBT ko4 hybrid turbo, ko4 charge pipework, bracketry, oil lines etc, I also bought a trackslag downpipe, bigger injectors, gas n gears lightened g60 flywheel, Wavetrac LSD, even splashed out on an Emerald K6+ ecu.
Stripped the engine right down and cleaned it up a bit, started to bolt on all my stuff in prep for putting it in.
Stripped down all the wiring and made up my own 1.8t to ce1 conversion loom
Before i could drop it in i wanted to paint the underside of the car, so ALL the underseal was removed, took an entire weekend of non stop grinder action with various knot wheel attachments, got to the final area and then my old trusty dewalt grinder packed in!
In the end i got it all off, welded up any holes that were discovered, seam welded about 80% of the floor, zinc primered everything, then stonechip, then primer, then a good couple coats of Audi IBIS white, which i plan to paint the car in eventually.
Also refurbished a bunch of suspension/steering parts in order to get it down and rolling again, triangulated VW motorsport inspired rear beam, seam welded wishbones, polypushes all round, refurbished steering rack etc etc etc
Boom, its down on the ground again, time to get the engine in!
Long story short got it running fairly decent off the Emerald K6+ with some bigger 550cc injectors, had to teach myself a bit about injector scaling which was quite fun.
Heres a quick youtube vid of it running...
https://www.youtube.com/watch?v=W5M074arAwM
Cage time! Ripped out the engine and box and the car went off to Aiden at Lochaber stainless in Fort William to get a full 6 point cage designed and welded in, it is also welded through to the front turrets.
Thats about it for the FWD stuff... Sudden change in direction to follow shortly!
