Hi All
I have an issue where my brake pedal does not return, brakes work fine but when pressed the pedal stays down, can you advise if there is a brake return spring fitted on the pedal mechanism?
only way to get the pedal to return at present is after using the brake is to place foot under pedal and re lift it back in to place or alternatively I will have to use a small bungee cord.
KR
Stephen
Brake pedal return
- steve GT VW
Re: Brake pedal return
There is a spring on the pedal, check yours is not broken.
Picture here.
https://volkswagen.7zap.com/en/rdw/scir ... 21-126000/
Picture here.
Might be wrong.... as last post for a left hooker..
Have a look here and check your springs/set up
https://volkswagen.7zap.com/en/rdw/scir ... 21-128000/
Village Idiots
Had this problem with my Corrado, but on the clutch pedal (hydraulic clutch). 'Twas a faulty master cylinder.
- steve GT VW
- essextom
check spring number 4 is still fitted correctly
sorry to hijack thread but if you wanted to adjust the pedal postion is there facilty to do it?
maybe slacken the buts on rods 5 and 19 to tweak the lengths?
